Capn Pete
Being fairly new to cp helis, I'm getting a pretty good handle on regular 6g flying . I would like to start learning 3D. I've been told it involves more guts than skill! I believe it. I'm still unsure how to use the dual rate switch or when. Is it simply when you want to use a higher or lower rate of speed for different types of flying? So if you want to fly with less power, say when you're first learning, you use the lower rate? I think I'm doing it right so far. I switch the idle mode on to lock in the throttle speed, then switch to 3D to remove the safe mode. I'm flying a Blade 130S.
Thanks! Also be aware of HR 302. This bill if passed will remove rule 336 which protects our hobby from the FAA
