I'm sitting here working on the Rogue 3D Bipe getting all of the control surfaces setup and I found a major issue that could result in you losing your plane, or injuring someone. All of the control surfaces are working great EXCEPT the up elevator. When I slam the elevator stick down (up elevator), it either limits the movement of the elevator, or it doesn't move at all. I thought it was my DX8 at first, but I went out and tested this theory on my Edge with the AR6200 in it, and everything is perfect. It's the OrangeRx that is causing this issue.
If you are doing a dive to the ground, or a stall and try to "snap" the plane out of it by giving it quick full up elevator, you will crash you plane, injure someone, or damage property. I'm sure the control surface could be different on each Rx, but this is worth noting.
To test this if you have a DSMX Tx, and the old OrangeRx, test each control surface (aileron, rudder and elevator) by slamming the stick one way or the other. If at any time you have any issues with the servo not moving all the way, DO NOT FLY THE AIRCRAFT!
I just wanted to post this since I just found it. This is a serious issue and it's not the Tx's fault, it's the cheap Rx components. Use a good Rx made by Spektrum. Trust me, your $300 plane is worth an $80 Rx.
Feedback is welcome if you have had this issue or if you have questions.
