James M. Lewis
Armed Forces
Just to bring you up to date of what I'm doing. After getting my TREX clone already to install in my Augusta A109, I change my mind after much thought. Being this is a belt driven bird, would have to make some modifications in order to install the tail rotor. Even though I cut out the required area for such an installment, it still would have been a bear to do. Looked like cutting the cone end off to mount the tail rotor and make a sleeve inside the fuselage to secure it in place. So what I decided to do was put my Gartt 450 Pro in it's place. Reason is it's torque driven (a lot easier to install, no additional cutting) and inside a fuselage tail better protection in a crash. I'm also in the process of converting it to a FBL helicopter. Have already got a DFC head that I ordered and shopping for a 3 axis gyro. Since she already has Gartt mechanical and electrical parts, might as well do it right. At the same time I'm doing this will custom build a 300 Hughes bubble canopy, vertical and horizontal fin for my clone 450. I first made a mock up of the bubble head out of cardboard to scale and quite please with the results. Will make the final one out of 1/8 acrylic secured with micro screws and small acrylic squares and super glue. The bottom of the canopy with two small holes, will be fasten to wooden dowels that will be glued to main frame. The top back of the bubble will be screwed in place with aluminum strips attached to the main frame in front of the rotor head. Fins also will be made out of 1/8 acrylic. So when I finish these projects all my helicopters will be scale. Hope to have a maiden flight for each bird by the end of the month or early August.
