Misc DJI F550 Hexa
WyDiablo
What do you guys think about putting bigger (Power wise) motors on the hexa? With bigger motor would probably mean larger esc also.
Thanks
breeze400
Spagetti Pilot
Yes I would think bigger motors mean bigger esc! Question in do you need it? You will also use more power. Meaning less flight time too.
WyDiablo
Thanks, just a thought I had. I knew that bigger motors meant bigger esc, bigger batteries maybe and less flyinh time
The only time you should need a bigger motor is if you need the power. If you are having to lift more weight (cameras, larger batteries, whatever) then yes, upgrade the motor. Putting bigger motors on just to say you did will do nothing but draw more power as stated above.
