I think one of the issues is the DFC head probably should be maintained more so than others. As Steve said the links getting sloppy, is a weakness in the metal to plastic connection there, also if your not a regular maintainer of your head dampener bushings when that grip starts getting any up and down movement on it because of the damper bushings wearing, it's gonna pull push a boat load of times up and down on those plastic links, leading to the eventual failure there. So the head, and bushings need to be always snug and tight...
