Congrat's on the maiden, looked pretty good.
About the wobble you guys are noticing, Where is your COG on your quads?
I know on the Wasp 280 the weight is a bit lower and centered under the main plate. I am curious if the battery on top is rolling the quad when off centered. I.E. motor corrects, and the top weight helps push the correction once knocked off center? I guess this is what the PID adjustments are trying to compensate for.
