Please read carefully.
I have a semi built , (to a good standard) a Flair De Havilland Tiger Moth.
It is far from finished, and is all still in airframe position, Lower main wings not even built. and loads of work required before you can consider dope & Tissue stage. I also have a fine glass mat covering, as I was then going to do the Laminate trick, to give the plane the original look. I also have the decal set, also flair. there's way over £500 at Flair costs.
If you would like to finish this kit of, here's the catch, you will have to collect and a donation of £50 to RC-Help.com.
So if you interested drop me a line.
