cml001
I have MKS 92A+ cyclics on my 450PRO DFC.. Had a good crash the other day and ended up with this... Ele servo seems good, one of'em the cyclic has a "noch" in it, & the other is limp... It moves freely, as tho there was no gear at all.. However, if I power up... It works(bench test only).. If I press on it while powered it holds fine... In all positions... Stick movement is fine... What's the deal? Should I replace the gears in this servo when I do the the one with the "noch"?
