concodd
I would like to get member's view's on what they think is the better connector's are, the XT series or EC range and which are the easier to work with from the point of view of soldering to cables and the actual separating from each other. I have been using the EC5 for my 700 build, I did have problems with the ESC cables because the wire was so fat, getting it into the cup at the end was difficult, maybe I should have trimmed the wire down to make it smaller? Not sure if using the XT range would have made the job easier or not. Having looked at the XT closer on Batteries that I purchased, they seem to look easier to work with, and look like they can take more heat in the soldering stage before they start to change shape with the heat.??
