i watched the video on how to build rc help trainer
so i built that plane
i want to make it fly but the rc store in our country dont have the exact products
so i have bought
avionic 9g servo * 4
brushless motor of odin 2730 KV 1300(thrust 440gm,Cell - 2 cell / 7.4V Prop - 11 x 6 ESC - 18 amp) * 1
propeller 10*6E * 1
pin horns 9*13mm * 4
wolfpack 2200mah(20c,11.1v) * 1
wolfpack charger(B3AC 2s/3s compact charger) * 1
motor mount for 28 series * 1
push rods(M2*L550) * 4
JR extension 30 cm(22Awg) * 4
nylon clevisis(3*L22mm)
nylon arms(2.8*6*7.5mm)
3.5 gold bullet connectors
dean plug T-connector
esc Avionic 20Amp
and
FS-CT6B 6ch 2.4GHz transmitter & receiver
so i want to know that will this set up work if i connect it
and will the battery will charge with this charger
and will the esc work with motor mentioned above
please reply to the question
thank you
so i have bought
propeller 10*6E * 1
esc Avionic 20Amp
and
thank you
