Rick Stoll
I have a new T-rex 600n Super pro.. although it is an older flybarred model guy never flew it
I went through the whole complete flybar setup..i ran into a glitch while setting collective pitch...when I try to lower the swash plate to even out the positive and negative pitches.... the max I can get is about 9.5 degrees positive and negative due to the fact that the center guide that traveles up and down will go lower than the guide pins... I can set it up to have more positive but cant get more negative once I go to negative collective and it drops off the guide pins it wont go back up on the guide pins without my hand actually lining it up as I apply positive collective
Do these pins unscrew so I can get more length out of them?...I tried but didn't want to put a lot of pressure on the pins in case they are a permanent fixture to the head assembly
