General choosing the right battery for my rc airplane project
Rajnish Nayyar
Dear
Require help in this I had a motor
Motor Specification:
Brand: XXD
Item NO.: XXD A2212
KV:KV1400 , KV2200(optional)
Dimensions: 27.8 x 27mm
Shaft diameter: 3.17mm
Battery: 2-3 cells lithium battery
Efficiency: 80%
Current: 4-10A (efficiency >75%)
No-load Current: 10V/0.4A
Max. Instantaneous Current: 12A/60S
with ESC of 30A
what would be the right battery how much it should have the Amp, C ratings and MAH
Its 1000 KVA motor
Which battery and prop you use will be determined by the specific airplane model. Look at the recommended specs that came with the plane. You already know it will be either a 2 cell or 3 cell battery just from the specs you gave. The prop will also determine the number of cells you will want to use. Finally the MAH capacity will be determined more by the wing loading and current weight of the plane.
In addition... You should pay attention to where you are posting your questions and place them in the proper forum area. This is the FPV forum area and not one of the airplane forum areas. You may have gotten more responses in the proper area.
