  3. Like Us On Facebook!
    Dismiss Notice
Dismiss Notice
Flight Controllers Changing Firmware On Fc
Discussion in 'Multi-Rotor' started by bigone5500, Feb 23, 2018.
< Nicked Blade...ok? | Screw Assortments >
  1. bigone5500
    bigone5500 Well-Known Member
    Mar 22, 2017
    2,601
    68
    58
    Louisiana
    I have firmware on my stack-x that came from the Banggood website. My quad flies pretty well. If I change firmware, will I have to setup all the settings again?
  2. Admiral
    Admiral Well-Known Member
    Mar 2, 2014
    2,148
    128
    73
    Gender:
    Male
    Occupation:
    Information Technology (Retired)
    Brisbane, Australia
    Yes you will a firmware upgrade loads a default version onto the FC, although on some of them you can save your settings and them load them after the re-load.
  3. Tony
    Feb 21, 2011
    37,144
    1,458
    113
    Do a diff all dump and just upload the output after you change firmware. Just remember this was a custom firmware to control the camera and such. You will lose that on the stack x if you upgrade. You can also just run a dump command and it will output everything.
Share This Page
