So...here's a question that came to mind today.
How can I be sure that my servo's are "truly" centered? If the sub trims are at zero, the tx trims are in the middle position......when you power up the servo's, are they then "truly" centered?
I'm having some troubles with my 600, still.
After getting my servo's centered (I think they are centered), getting the servo arms 90'd (I think they are 90'd), getting the linkages 90'd to the servo arm (I think they are 90'd). When I go to level the swash plate, my aileron linkage needs to be lengthened quite a few turns and the pitch servo needs to be shortened a bit. The DFC linkage arms are as short as can be and are the same length. Then when I check the +/- blade pitch..it's insanely WAY OFF.
Anyway..I'm sure i'll wanna talk more about the 600 in my 600 thread, but I am just wondering about getting the servos "truly" centered.
