Currently I do not have nor do I want autorotation activated.
The motor engages as soon as the throttle stick is lifted off 0% (which is good) and soft start initial spool up rate is set to "medium" (5) in CC program.
However, after spool up/soft start, if the stick hits 0% (all the way down) this activates soft start again. If this happens during flight the spool up rate is not fast enough to pull her back into the air. She will crash. I rarely fly in IU as I am still learning.
So, I think I'm gonna increase the initial spool up rate to "8" and see what that is like.
QUESTIONS:
1) After changing initial spool up rate do I have to recalibrate ESC endpoints?
2) Do I have to re-bind the BX after any of the above referenced changes?
Any answers or suggestions are appreciated.
QUESTIONS:
