ESC Castle HV160 cell count
fran11784
I have a CC160 using with a 12s setup. But when I plug in the flight pack I only get 11 beep from the ESC. Is this normal? Pack at 46.3 volts
stokke
No, that is not normal. It should count 12 times if you are running 12S. Try swapping out a 6S pack with another (if you have more than two packs that is).
pvolcko
That voltage is a little on the low side. 11S fully charged is 46.2V so the fact it is seeing 11S makes sense in this case. Charge the pack up and it will see 12S more than likely.
fran11784
^^ your right, I learned something. Seeing a fully charged 11s. Spoke to Castle and he said if I'm ONLY useing a 12s on this model then I could set the cutoff to 38.4 instead of auto Lipo. Any how thanks! Ill charge them tonight and try but all should be well
