I had my little MCPX get away from me when the wind picked up. Had to cut the throttle before it ended up going over the fence into the local dumpsite LOL. It must have landed on its side cause two of the canopy mounts broke.
So here is a mod to fix your broken mounts. There are a few methods, this is one.
Back mount is just glued back on with plastic epoxy.
Replacement front mount CF 2mm rod filed at the ends to fit the canopy grommet.
Glued across the top of the board mount.
Moved rear grommet to keep canopy level.
In the last photo you see that the new mod gives more room for the board in case of a crash the canopy isn't pushing against it.
