The lite doesn't have much of a heat sink. So it needs to be in a decent air flow or be overrated for its application.WhAt are the differences between the 2? I know One is not as thick as the other.
The KDE peaks more then double that. You will be fine with the lite versionI would be running a Scorpion 2221-8 that runs at 45 amps peak. When I looked at the ESCs that was the only thing I could find as being different (heat sink). They are both the same price.
