500 Building the Gaui NX4
stokke
It finally arrived! Well, it didn't take THAT long, but I had hoped it would show up Saturday. Anyways; Westy posted a video of this bird a while back. And watching that video really got me fired up! So I sold the Align 450, and got this baby - my fist nitro I might add :D
WOOHOOO! Always like Christmas on days like this :D
There's still parts missing, but they'll get here!
Oh yeah, a big thanks to Sam, Tony and Gaba who helped me figure out what would be needed and educated me on nitros in general :D
ON TO THE MAN CAVE!
Island Breeze
Senior Rc-Help Member
WOW! Tony picked up is old 450, westy with his goblin, Dan and the PROTOS did I miss anyone....is this Christmas in June, got to love it. Addiction people.
stokke
The forum is seeing a lot of new birds alright. But that's just great :D Means the hobby is alive and well!
Got the Align starter and a battery for it.
Flying-Hobby sent the wrong battery. I ordered a 45C pack which is the correct size, but they probably ran out and sent a 65C pack instead. If this was for a 450 I would be delighted, but now the pack won't fit... But no worries, I'm sure I can swap with one of the guys in the local club. Who says no to a 65C pack, right?
Fuel pump. I considered an electrical one, but I thought it'd be overkill considering the small tank on the NX4.
Motor and muffler.
The tiniest motor ever LOL :)
Got the Align 500-series servos. I realize one's missing - it'll be delivered within a couple of days.
The stock Gaui plastic fan reportedly warps after a while and throws out the gov magnets. So I got the Align 600 fan (supposedly, it should fit).
Gaui glow igniter and BEC. A guy told me the 5A bec may not cut it - what you guys think?
Radix main blades.
Let's build a helicopter!! :)
The instructions and bags are poorly labeled. And even though some of the bags ARE labeled, the labeling does not correspond to the instructions. Even when I download the latest revision of the instructions, the updated instructions does not correspond with my bags. Parts and build quality is just as good as any bird I've built before, but the instructions are a disappointment :(
These labels are useless.
Sanded my frames.
Main blocks.
Frame brackets.
With the instructions being so crap and the bolts and hardware randomly packaged, a caliper is a must have.
The countersunk bolts does not go completely into the frame bits, so the surfaces is not perfectly flush. Hmmm :(
Assembling the first bits of motor gearing.
This little bolt is supposed to go through this shaft. But it's a incredible tight fit! I had to dry fit it first before assembling it under the main blocks.
After a bit of fidgeting I finally got installed.
Boom mounts.
I believe this is for the rudder... Not sure yet.
Both frame sides assembled together :D
Westy
LEGEND
DUDE! I totally rate this! wicked purchase! I actually like the simple manual layout also .... the Goblin one I struggled with some parts with the black CF frames and all the screws disappearing into them.
I will be following this build as I almost ... almost pulled the trigger on this instead of the 630! .... Lucky I was allowed some extra funds or this would have bee na tough tough choice between the 500 Gobby and this!
coolgabsi
Super Mod & DEAL KING!
Looks great Marius!! Bec can't hurt bro. I put a bec on my warp as u heard mks servos sucked juice. It's insurance abd peice of mind IMO if nothing else :)
While my align 2in1 and ds610's are doing fine on the 600.. But it can differ bird to bird
Fly safe!! :) have fun!
breeze400
Spagetti Pilot
Looking great Marius! There's allways some glitches with all builds. And yes that swing arm is you rudder! Lol
stokke
Thanks for the comments guys :D
Assembling the clutch bell. This assembly comes with a small revision from the instructions - an extra shim is to be installed.
Stock plastic fan to the left, Align 600 fan to the right.
Placed the fans on top each other for comparison. Perfectly identical.
Glued in the magnets. I think I got them mounted the right way...
Fan assembly. This also came with a revision - an extra shim here too.
Clutch assembly.
Motor covers.
Motor mounts.
Landing skids.
And that's it for tonight. I ordered the missing stuff today, so if I'm lucky I'll get airborne this weekend.
Westy
LEGEND
That looks sexy as! ...... I would have thought you would see a helical cut gear one the main gear drive.
Sweet dude,
I would love to give a nitro a go, but maybe i'd like to try a gasser for the cheap fuel.
stokke
Thank you for your comments :D
Continued with the build immediately after work today; main and tail gear install.
Head. Came pre-assembled.
Sam warned me about ordering a bunch of parts before I got the kit - and he was right :D I ordered the red (harder) dampeners, but they were already included with the kit. Well well, guess I have spares then.
Removed stock black (soft) dampeners, and replaced then with red (hard) ones.
After removing the feathering shaft from the head, I thought I would add new thread lock on both the bolts. But I could not for the life of me remove the last bolt! It was on there GOOD! The people over at Gaui must have used a whole tube of red TL and applied a ton of torque on this bolt. I even warmed it up almost to the point it was glowing red - but NO GO! Well, I know it's not gonna come off during flight, so I just left it as is.
Small note: there is a plastic shim between the head and arms, but ALSO a very thin shim that is not depicted in the instructions. I left it on there.
Head assembled back together and checked for TL on all bolts.
Swash, checked for TL. I'll just consider myself part of the "3D Master Club" now :D LOL
The instructions calls for the head to be installed now, but I will wait until I have set up my servos first.
And now for the "battle at man cave" against the fuel tank beast... MY GOOOOOOOOOOOOOOOOD I HATED THIS ASSEMBLY. This is the most idiotic assembly I've ever come across. :( I get angry just writing about it!!
Got some extra fuel line.
Assembled the clunk (mistake!). This was pain in the behind - with capital B!!! Threading the line over the flanges proved extremely difficult - at one point I almost threw the whole thing out the window!!
Found out I had to take it off again!!!!!
Because this thing is supposed to go on first... OMG
Now to press this assembly into the small hole in the tank. Easy? Yeeeeeeeeah......... The curse words. Oh, the curse words. The man cave was no place for children during this install that's for sure!
Tried this method. Plugging the big piece in first, then try to press the rest in. This resulted in the whole assembly popping inside the tank!!! :( :(
Fished out the assmbly, had another go - this time I hurt myself and the clunk fell of the fuel line inside the tank!!!
After taking a break to cool down, I sanded the edges of the tank- washed it out thoroughly with water - plugged the plastic end of the fuel line inside the big rubber grommet. Then I oiled the edges and grommet, used a small flat screwdriver and finally got it in there.
THIS ASSEMBLY SHOULD HAVE COME PRE-ASSEMBLED!! ARE YOU HEARING ME GAUI!!!?!!
Even though the manual states the included fuel line is Ø5.5mm and the Align fuel lines (which I got as extra) was supposed to Ø5mm, the Align line (green) looks larger?
Planning how fuel lines are going to be run.
Tank mounted.
Auxiliary fuel tank. This luckily came pre-assembled! Whew!
The aux fuel tank comes only with one single screw to hold it on to the bird, so I devised some extra support.
Good as gold :D
Got the Align fuel filter.
Finished running the fuel lines. Nitro people, please check I've done this correct.
Even though this part of the assembly took a few years of my life, I'm quite satisfied. Now I'm just hoping my Sat's and governor sensor will show up within the weekend.
breeze400
Spagetti Pilot
Looks good to me Marius! Next time get yourself a jar of petroleum jelly to assemble things like gromits and o rings. Works wonders! Lol.
Really nice Marius. I've been looking at the X4 ii and the X5 formula. If i sell my 600, i may be tempted with one of these.
Westy
LEGEND
Looks fantastic! ...... Re your feathering shaft..... try warming about 20 to 25mm of the shaft to about 180ºC and holding it with your locking tool ($6.00 at HK all 4 sizes on one tool - 450 - 700) and tap the head with a soft mallet about 10 times .... it should crack free and come out !
stokke
Thanks Sam, will do! ;)
Seen some vids of the X4ii, looks awesome! Thanks Lee.
Nice job bro!!!
Thanks buddy :D
Looks like its coming along nicely mate
Thanks Dan :D
Thanks Westy. This feathering shaft is not coming out again unless I have a crash or something is wrong :D :D :D Thanks for the tip though ;)
