Mohamed Emam
Hi Guys,
I am planning to build Boeing 737-800 and I am looking for its plan. Can someone help?
You going to make a balsa build or foam?
Using edf?
Using edf?
What scale are you trying to achieve?
I'm not that familiar with cad yet... but i'm getting there with it... shouldn't be too hard to get the scale out of cad, and then print direct from cad.
What size edf are you going to use?
I have an 80mm delta 32v edf unit with matching e-flite inrunner and i was told by the guy at my LHS that with this unit it should hit speeds close to 100mph and to definitely glass the entire plane otherwise it will decinegrate in mid air especially since it is foam i am going to build a me262 jet fighter with 2 of these units on mine.. Here is what i got which the impellers on my unit is only 5 blades the ones you showed that you will be using although smaller in diameter has double the impellers which all the difference in the world...
Yeah I'd certainly be glassing the motors in and the wings onto the fuselage.
Although with the 737 you probably aren't going to need the 100mph speed!
I'm guessing that you are planning on trying to fly it scale? (meaning you don't want to do loops and stuff)
Are you getting the oleo struts the hk has for the passenger jets?
I'll have a look at scaling and i should be able to give you rough dimensions
it will more then likely be a bigger jet then the one i am going to build so the extra impeller blades will defiitely help propel it and no i am not saying what i have is better then what you want to use by no means turnigy makes some good motors i have a turnigy typhoon 500 class motor in my hk500gt heli very strong it is what you want to run.... i am always on a budget so normally i purchase stuff fro hobbyking but when i bought my e-flite i had a lil extra cash at the time...i am really looking forward to your build i love passenger jet rc planes.... i actually will be running 2 85 amp turnigy esc's for my edfs
These are the retracts I was thinking of out of hobby king
Turnigy Alloy Servoless Airliner Retracts w/Sprung Oleo Legs (90mm 737 / A320)
With the motors I really don't know. I am not too clued up on the edf's at the moment. Plenty of other guys here will have a much better idea than I do when it comes to edf's.
My only thought is making sure that the housing remains scale...
I look forward to seeing it up and running and seeing your build logs
