Motors Blitz RC Super Sky Surfer motor upgrade
FPV_Pilot15
Hi
Can anyone possibly recommend a motor that could replace the stock motor on the Blitz RC Super Sky Surfer by banana hobby? The stock motor is a 1250kv and the flying weight is about 2kg. The propeller description is not displayed. Some forums say that a 1500kv might be nice with a 3S Setup with a 9" prop. and some say that 500 watts is required at least. Can you recommend a good motor upgrade that is close to or if not higher and/or better than the 1250kv I specified taking into consideration the flying weight of 2kg and prop type + ESC? I will be using this plane for FPV soon as it is a huge glider with a wingspan of 2.4m I am trying to keep the power to levels which are more than adequate. Can someone as well recommend a good battery type and propeller if there by any chance a motor upgrade is not needed and a change in prop and battery size is more suited?
Thanks
Super Sky Surfer RC Sailplane Glider - Radio Controlled Super Sky Surfer Electric Sailplane - RC
