Have you weighed the blades? If they are more than a couple grams from each other, they could cause a vibration. Watch my "How to balance blades" video and check them out. Make sure to check out the CoG as well, it's just as important as the weight.
Any little tear in that plastic coating has always caused problems for me. At high rpm it lifts away from the surface of the blade and can cause vibration.
Thanks rchelipilot good info. I need to do some tender repairs being a tight old bugger short on cash I did not want to throw then away. Could always cut then down to a 300 or 130 LOL. Cheers
Don't know what size blades your talking about but the last 2 pairs of Align 325's I bought both were not balanced out of the package. I thought my main shaft had to be bent.
