  3. Like Us On Facebook!
    Dismiss Notice
450 Blade 450 X Helicopter With The Beast X - Ar7200bx
Discussion in 'Helicopters' started by ABriscoe, Jun 12, 2018.
  1. ABriscoe
    ABriscoe Member
    Aug 28, 2014
    30
    0
    6
    Gender:
    Male
    Jacksonville, NC
    I have a Blade 450 X Helicopter with the Beast X - AR7200BX. What I need to know
    is what should all the settings be in the Spektrum DX7s Transmitter.
    In the manual that came with the helicopter it has some crazy settings that I don’t
    think are for me. I don’t fly 3D so all I want is the basic setup for the transmitter.
    Could you please help me with this. I have watched Tony's video on how to setup
    The AR7200BX.
    I attached a photo of the manual page for the transmitter settings that came with the copter and if you can tell
    me what I should change for just normal flight.
  2. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    What settings are you thinking are not for you? Because those settings look pretty good other than the N throttle curve. For that I would run 0 60 60 60 60 and get rid of that 30. Better when trying to lower in altitude a little quicker. Pitch curve, I run 46 48 50 75 100 in N, but with their numbers it will just give you more negative pitch to hold you on the ground which is always good.
    The BX is really good at making for a soft feeling helicopter so if you set it to sport (I think), then the DR/Expo numbers look good as well.
  3. ABriscoe
    ABriscoe Member
    Aug 28, 2014
    30
    0
    6
    Gender:
    Male
    Jacksonville, NC
    Once again Tony, Your The Best... Thank You!!!!!!!!
  4. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    It's my pleasure! :thumbsup:
  5. ABriscoe
    ABriscoe Member
    Aug 28, 2014
    30
    0
    6
    Gender:
    Male
    Jacksonville, NC
    One last thing Tony, to setup the Beast-X do I make all the "n" settings to linear?
  6. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    I'm not sure I understand the question. Are you talking about Menu N? Because that is just a test menu where you rotate the helicopter around and make sure the swash stays in the same orientation in space, no matter the helicopter position. But I have a feeling that is not what you are referring to.
  7. ABriscoe
    ABriscoe Member
    Aug 28, 2014
    30
    0
    6
    Gender:
    Male
    Jacksonville, NC
    In the Transmitter. They say that when you setup the BeastX you should use a linear curve but the photo settings that I posted they
    are not linear for the transmitter.
  8. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    Oh, now I'm up to speed lol. You definitely want a linear pitch curve in your Tx so that mid stick is 50% pitch, low stick is full negative and high stick is full positive. Once all of that setup is done, then you will go in and set the pitch curve to what it states in the manual or what I stated before, your choice.
  9. ABriscoe
    ABriscoe Member
    Aug 28, 2014
    30
    0
    6
    Gender:
    Male
    Jacksonville, NC
    Should it just be under "N" in the transmitter or should it be all?
  10. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    Just N, or Normal mode. You shouldn't have to ever move your idle up, or F-Mode switch during setup.
  11. ABriscoe
    ABriscoe Member
    Aug 28, 2014
    30
    0
    6
    Gender:
    Male
    Jacksonville, NC
    Again, Thank You Tony... Sorry to be such a pain. Your the best!
  12. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    Not a pain at all bro! I'm just sorry I didn't pick up what you were putting down earlier lol. Only thing that I could think of was menu N in the BX but I knew that couldn't be right lmao. Hope you get it in the air soon!
  13. Emilio Rossi
    Emilio Rossi New Member
    Sep 2, 2015
    6
    0
    1
    Rome nY zip 13440
    I'm trying to set up my ikon2 with my spectrum 8.Every thing is working but the throttle hold.when you flip the switch it shows that the throttle hold is working but the helicopter spoils up.all the holds are set to hold.I bound my spectrum dx6i to the helecopter and it is working fine.I'm I missing somthing.
  14. Tony
    Feb 21, 2011
    33,765
    1,308
    113
    Hold the button on the roller and turn on the DX8. Scroll down to F-Mode (I think that is what it is called, don't have my Tx here with me) and make sure hold is enabled in that menu. Then, go into your throttle settings and make sure H is set to 0 all the way across.
  15. Emilio Rossi
    Sep 2, 2015
    6
    0
    1
    Rome nY zip 13440
Share This Page
