Blade 400
Hi all,
I have finally got round to fixing one of my Blade 400 Heli`s that I crashed a while ago (been having too much fun with my new Tarot 450 fbl v2)
I have replaced two servos as the gears were stripped, replaced the boom (boom strike) and I am trying to separate the blade grips from the feathering shaft, they won`t come off???
Having disconnected all four ball links, I have used two 1.5mm drivers and turned them anti-clockwise, one of the bolts has come out with a few washers, but the other is just turning. I have tried pulling one blade grip off but it`s stuck fast???
I don`t want to break or damage anything else, the feathering shaft is definitely bent. I`m thinking of applying some heat with a heat gun?
Can anyone please advise on the correct way to replace the shaft?
Many Thanks
Many Thanks
