Blade300x spins at mid stick
Good day all,
Needing some help with my 300x because it spins hard left about half stick and when I try to correct it, it spins hard right which prevents me from taking off. I replaced the main frame and put it back together and since then it won't fly. The things I've done, replaced, and checked are as follows:
- replaced tail servo and doubled checked belt direction
- set servo arm at 90 when after initialized
- centered tall rotor slider
- reset DS6I transmitter back to user manual settings and and made many adjustments
The heli now runs (blade spins) when transmitter is turned off and heli battery is still connected. I'm all out of answers and needing some serious help.
Vmoon
Good day all,
Vmoon
