I need to extend the BEC harness that goes to the AR8000 throttle. Can a standard servo harness extension work for this. The BEC has a larger gauge wires compared to the servo extension.
Smaller gauge wire on the BEC will be fine. I have extended them many times with a smaller gauge extension. But if you are worried about it, use a Futaba heavy duty extension lead.
