450 Bearing Replacement
I started working on the tail block and somehow managed to damage one of the bearings of the torque tube gear. (the most backward bearing on the gear that connects to the torque tube.
So now I'm looking for bearing replacement and I can either order a new set of bearings with shipping cost being almost the same as the costs for the bearings or I can go to a local hardware store and try to find bearings with the correct specifications (6x10x3 mm).
What would you recommend. Go for original rc heli bearings or are general bearings with the correct dimensions suitable for my 450 clone?
Go to rc bearings .com or Boca bearing .com. Not sure of there urls. All you need is the measurements, inside diameter, outside diameter and thickness.
