Heliman450
Hi all, similar theme to my 450X thread but for my second heli. I bought this one as my first kit project in Singapore 2009. Now it's taken second place to my Blade 450X. I didn't want to lose touch with my flybar heli, hence, returning to it. My former heli guru recommended to change the servos, so I had bought three Savoex in 2014 and an Align tail servo (exact serial numbers escape me right now).
I stripped out the old servos and the Rx. as it just didn't fit well in the frame (no need for a 9 channel Rx.). Then checked it over mechanically and found a loose screw and its partner missing. I replaced them using some red thread glue. I don't think it was a big problem but the designer thought they should be there .
I fitted the servos and ran the wires left/right for the best route into the Rx. Today was set-up day. I watched Tony's video before starting, well done Tony, you didn't have the same problem I got, but there was enough food for thought in the video, thanks very much. My most difficult problem was with the pitch and aileron servos needing to be reversed so that the swashplate operated correctly. My elevator servo was ok so the swashplate was tipped back as it moved up and down with the collective input.
I'm not setup for videoing just yet so sorry for now. Soon, I'll hopefully be able to do some troubleshooting videos and will go back over these issues when I feel more confident with my skills to go "worldwide".
Enough for now, the heli is sitting in the workshop waiting for a test hover, which I plan for Sunday afternoon.
