Hello,
I am new to RC'ing. I bought a used Traxxas 4x4 1/10 SC truck. I am in need of some battery advice.
Current motor info:
Motor - Orion Vortex Experience 2 PRO, Max current 70A, PRM-V 3750kV, Turns 10T, Voltage 3.2-11.1V.
Current ESC info:
ESC - Dynamite FUZE 1/10 Sensored Brushless FWD/REV, Max current 70A, Input voltage 7.2-11.1V, Motor limit 8.5T, Momentary peak current 100A, BEC voltage 6V.
What should I be looking at battery wise?
What would give me fair to good performance with a long battery run life?
What are my limits on battery size for the above listed set up?
If I understand batteries? The larger the mAh, the longer run time I get? The higher the Voltage (S value), the more performance I get?
Thank you in advance for your time and help.
Scott
Current motor info:
Current ESC info:
Scott
