OK got it, would this be a decent battery, Blue Lipo 6-Cell 3000mAh 22.2v 6S1P 20C RC Battery. Is that a decent ESC also??
Basing this info off of a RCM-BL600M HML60M01 motor ( I believe this is what Align sells in their 550 size heli, I'm not saying this is what you have since your the only one that can say for certain on that note )... the motor will pull 80a continuous and 95a burst
Those batteries are not enough to provide the needed amps.... 3000mah 20c batteries can provide only 60a at best, most batteries are over rated so assume that 60a is only on a good day to play it safe. To be able to provide up to 100a of current... you'd need at least a 33.3C battery if it was a 3000mah capacity battery ( 40C actually since I don't know of any 33C )
Figuring how many amps a battery pack can provide is simple math...
Take the MAH rating and divide by 1000 and then multiply by the C rating....
Using the batts you asked about as the example...
3000/1000 = 3.... 3 x 20 = 60a
Going another direction on the batteries...
For a 3000mah battery to be able to provide at least 100a of current... you need a 40C or better C rating
For a 5000mah battery.... you only need a 20C rating or better
I mentioned that most lipo batteries have their C rating overrated... I believe this is true with Blue's also even though they are still decent batteries but at 40C, there should be enough overhead to still provide the amps needed. You may want to actually look at Gens Ace batteries instead... they cost only slightly more and their C ratings aren't overstated. I also believe that they will have a longer lifetime than the Blues in most cases.
