Capn Pete
Are all banana plugs (I think it's also referred to as a JST? The red ones with one male and one female plug end) created equal? I tried to plug in a 1500 mAH into a drone that uses a 2000 mAH and it didn't want to fit. I didn't want to force it. The 2000 ran out quickly and I was trying to just see if what I had on hand would work.
Also, are most balance chargers created equal? Will a basic balance charger that came with a 1500 mAH give a full charge to a 2000 mAH?
I assume that all 2000 mAH lipos are the same as long as the voltage is correct for it's use and the connector fits.
