Is the battery dead? No charge? If yes I have a recovery method that has worked for me on two occasions when I ran two separate batteries too low to charge
It's gone to 4%
don't know how cause the other pack that was with it in the trex 700 is still on 25%!
These 2 lipos I got from an online outlet last week, when they arrived they had badly soldered bullet connectors on ( not Turnigy items! ) I emailed the store about the one lipo getting very hot when charging with the other four and this is his reply
if you are using one board to charge all 6 lipos at bonce this is not good for high amp age lipos
you find you have a low resistance lipo and it will not charge up and you will end up boiling the chemicals in side the lipo .
so please send both the lipo back and we will refund you payment as 6 cell 40 c rated lipos need to be charged
at 3 amp plus and charged separately not with other lipo .
we will not be able to guarantee the lipos if you charge them this way.
this is the return address for both lipo.
Astra main unit
rapid rc
unit 4
Invicta business centre
Bredgar road
Gillingham
Kent
me8 6pg.
please do not charge the lipos this way and send both lipos back for a refund all you will do is one lipo will be full charged and the others will not be and the charge will keep on charging until the all the lipos are charged and you will end up with a lipo getting very hot and it will go up in smoke
so please send the lipos back to us for a refund asap be for you hurt you self.
regards justin
