Plug the AUX from the Board to your RX, into Gear channel.
Gear switch on your radio should then allow you to switch between Acro and Self level.
To check if the gear switch is working, goto the monitor menu in the radio, and flick the gear switch to see if it moves the cursor.
Give that a go and let us know if you need more help.
