Trucks Arrma Granite
Ben
hi all , i have an arrma granite 4+4 i purchased a hobbywing 1060 brushed esc for it . I run a 2 cell 5000 mah in it , however after only running a few minutes it reduces engine power way down , and if i turn it off then back on its fine for a minute then same thing , now i did run the lipo in it with it set to nimh batt by accident not sure if it damaged it or not. Battery is full balanced charged before each use .. please help
Check your ESC and see where the LVC is set to. You may have it set too high so it is reducing the throttle to help save the battery. For a lipo, I usually set this to about 3.4 volts per cell. You can go as low as 3.2 but you run the risk of damaging a lipo if you keep running it down that low.
Well, I just looked through the manual for that ESC and it is all done with Jumpers and there is no LVC option. It is set by default and I didn't see where it was set to. Make sure to do the neutral and endpoint calibration. Might help, but not sure.
