Hi guys,
I was just wondering if someone could tell how the AR8000 is powered, as far as I can see if you are using an ESC then it can be powered by that if it has an integral bec, however if you don't where do you connect a ubec power supply to ?, do you use the Bind/Data port ?
Thanks in advance
Acestu
Thanks in advance
Acestu
