450 Ar7200bx
Dano1
Parameter menu red flashing menu for B- setup control behavior I go solid red for Pro. when in this menu
should I have my gyro inhibited, cause when I do I don't have much rudder control, will the ar7200bx help in the control or do I need to start with the settings in the Manuel it said 54 across the board. please help.
Thank You
Danny
fran11784
Sitting board at work so thought Id try to help. So when in any set up menu the gyro is inactive. Gyro control and transmitter stick controls are disabled when the AR7200BX is in the Setup or Parameter Menu. If your using a Spektrum system, for the gyro gain I like to start low, about -35-40 in rate mode and maybe +25-35 in heading hold. You are going to fine tune this in flight anyway. If your using Spektrum, negative gain for rate and positive gain for HH. If your a new pilot, you probably want the control behavior in normal (purple) or sport (flashing red) Hope this helps, T
