I just watched Tony's video on setting up the AR7200BX.
Do you have to go through the entire process from start to finish? Can you do a few steps and then come back to it the next day?
You can, just make sure you push that button all the way through the menu's until it initializes itself. If you stop in the middle and power it down, you will lose all settings.
I was trying to set my AR7200BX. All was going well until I got to menu K. I had -10 degrees of pitch and only 1.2 degrees of positive pitch. It wouldn't go past that when I was moving the aileron. Any ideas?
