FBL Gyro Ar7200bx Setup Menu N
mhanley
I have an AR7200BX on a blade 360CFX. Both the normal and reversed setting in setup menu N causes the elevator servo to go full down. When I rotate the heli the swash tries to compensate instead of remaining stationary. I have called Horizon thinking I have a bad AR7200. They want me to send in the heli for them to evaluate the AR7200. I would like to avoid that if possible. Anyone have any ideas, could something else be causing this problem?
Matt
I think Smoggie is right, sounds like the elevator servo is plugged into the rudder port on the AR7200BX.
Either that, or the channels in the Tx are reversed.
mhanley
I guess I should have stated that the heli flys just fine, nothing is reversed. I noticed that it won't do a flat piro. This is something that just happened out of nowhere. I have leveled my swash with a swash tool. I have 0 degrees at midstick and a +12/-12 degree pitch range. The only thing I could find that didn't seem to be working right is the setup menu n piro optimization.
