Westy
LEGEND
hey there.
Hope I can get some help..... struggling to get this stupid thing to work.
For my New Goblin I amd running
Scorpion HKIII 4035-560 motor on 12s and running YEP 120amp HV ESC
Everything goes as per Mr Mels video on you tube .... and then when I go to spool up after settting the Gov Store.... it all goes pear shaped!
When I spool up (No Belt on drive of motor) it slowely revs to bout 25% and then stops .... doe sthis 2 times .... then the 3rd time .... it does it and then gives a big KICK! then it reves and revs ... but when you move the throttle up and down ... it is really slow to repspond (Not even close to being flyable) .....
Here are the SETTINGS I have so far
PAGE ONE
PAGE 2
That is all I have ...... not getting very far .... had gone over and over and over .... and did I say over it?
Hope someone with experience with these Controllers can assist
I thought Lee had one!
PAGE ONE
- TIMING: 6º (Scorpion recommed 5º) only chooise is 0 or 6 or 12 or higher ...
- Brake: OFF
- Cut off Type/ ACCu Type = Slow Down and LIPO
- Cut Off Voltage 2.4 - 3.1
- Cells 6 (Mr Mels recommendation as running on 12s and pack is at 3.9V as stipulated)
- Special Features (NONE SELECTED
PAGE 2
- ACT FREEW WHEEL/GOV MODE: ON FREEW on and GOV STORE
- GOV MODE P-GAIN: 1.2
- GOV MODE I-GAIN: 0.05
- START UP SPEED: Heli Slow (Have tried med and fast too )
- PWM FREQ = 8Khz (Recommended from Scorpion)
- Startup Power = 2%
