Island Breeze
Senior Rc-Help Member
I went thru one flight today on the GOB with no prob. took a break while the other guy took his turn to fly. I put a new set of batts on and low and behold no signal to the bird, the esc went thru its cell count and that was it. so I decided to reinitialize the ESC and this time my sats went into bind mode..WTH! unpluged and repluged batt and it did the same thing. So I decided to rebind at the field and "NOTHING". boy did that cut my flight time short.
now that I am home and i am going thru the wiring and all. Check! Check! and Check. ESC is fine..now the IKON. Plugged her into the PC and checked all fields. What nothing! this cant be. So I decided to just reinstall the default settings and redo it from scratch ESC and all. Before rebinding I removed one of two sats and bind the controller. That worked..i went thru the initializing of ESC and IKON and all went well, unplugged the batt, plugged in the other sat and went thru the bind steps again. this time both sats was looking like they were going to bind but just went blank. redid the process and it binded like a charm. Stressed at this time and with no beer in hand. I decided to go thru the process a few times of unplugging the batt and pluggin it in to initialize the bird. first two trys were successful, on the third attempt I had issues with the EC5 being loose and having me to move it around on the connector to get it to seat well, this caused a double spark before it sat snug ESC to batt. Low and behold IKON went into bind mode again. I had to go thru the whole process again of loading default settings in order for it to bind and going thru the pluggin and unplugging process without having to get that double spark. All seems good for now and will field test this badboy tomorrow. Oh! and as for the EC5..you know where they will be going soon..
