Harford
On my Trex 500 ESP (ie with flybar), I believe I have set up the head correctly according to manufacturers instructions and all is level (pitch at zero 50 in 50 out). With collective at max up, pitch both blades are +14.6 degrees, at max down -13.5 degrees. I would like to reduce the pitch range eg max pitch at high stick at say 10 degrees positive. How do I do this please on a flybarred heli ? My swash mix is at -55% for pitch. I understand you can adjust this setting to alter the pitch range but is seems to me it would have to be altered quite dramatically to reduce positive pitch from 14.6% to 10%. Your help would be appreciated.
