the 250 is a high vibe machine, so make sure you have everything lined up correctly bolts are snugged down well, the tail is not binding and the blades are balanced and tracked perfect, and the blade bolts are not to tight, oh and make sure you oil the bearings straight out of the box they will need it, I used two pieces of tape under my gyro and mine is sweet as a nut, I run V3.1 on the gyro as its working perfect on that heli,
