I am putting together a align 700E and I am not sure if I should grease the all of the gears or not. What do you guys do? also I have the DFC head and it looks like I would need to remove the main DFC blade grip arm if I should need to adjust the blade tracking, or am I wrong? Any ones help would be great. I am setting up the Castle 120 Ice and I am not sure if I should set it up using the multi rotor or the external govern, what are you guys using?
