Ok so 'im ready for first flight of my 550E DFC . Already spooled it up but i noticed that my tail rotor has got a twitch.... every 4 or 5 times it changes direction the 6th time it twitches very hard...its like it is binding on something but its not.
When i detach it from the push rod i can even move the tailblades by blowing on them so there is no binding there.
And the push rod moves freely too . So it can only be the servo or the AR7200BX that makes it twitch... anyway i'm pretty sure it is not a good thing to put up in the air this way....
any one have any ideas ? could the frequency setup of the servo in the AR7200BX be the problem ? i have the DS655 digital tail servo set at : 1520pulsrate (blue solid ) and at 333HZ (blue flashing)
should i try a new tailservo?
Any ideas are welcome...
Thank You .
Will post a video of the twitch so you can see for your self.
Thank You .
