Nitropropane
Is there any trick to get exactly 90 degrees servo on a servo?I tried my best with sub trimming but im never 100% sure that it's 90 degrees and its been making adjusting the swash difficult.That brings up another question.If the manual says that the rod should be so and so long from center to center of the ball links why do u still have to adjust it?Is the ,manufacturing process no perfect because no matter what i do i can never get a perfect mechanical setup on my swash.As soon as i get zero pitch when the blade is in the front and i turn it to the back its like 4 degrees positive.
