When spooling up the quad #3 motors does not catch up until over 50% but after that it's running normal when I bring it back to 50%. As I increase throttle on the tx the quad just sits there even at 75% throttle. Props are spinning correctly and they are not upside down. The gains on my naza atre as follows:
120-120-140-140
120-120
DYS 40Amp esc
DYS BE4108 580Kv motors
Spektrum DX7 tx
AR7010 rx
AUW 5.9lbs
11"x5 props
Esc's have been recalibrated 2 times and the Elev is set to normal in naza so when the stick is moved forward the slider goes to the right and when moved downward the slider goes to the left. I"m using the X4 type in the naza assistant. #1 motor is top right and #2 motor is top left #3 motor is bottom let and #4 motor is bottom right. I will post a video hopefully today with the quad at 75% throttle.
Edit / Delete Edit Post Quick reply to this message Reply Reply With Quote Reply With Quote Multi-Quote This Message
120-120-140-140
120-120
DYS 40Amp esc
Spektrum DX7 tx
AR7010 rx
AUW 5.9lbs
11"x5 props
