4S is not going to work it will spin the motor way to slow for a 550.Well i wase thinking that i could run the heli on 4s bat's,i just bought some vortex 25c 5800 mah,so i wase hoping that i could use them for the 550, i use them on my logo 10 with out any problem
so if that is posible i just need to know what pinion i nned for that motor
Greetings Rico
I think the 730mx would be a beast on 7S if I had a charger that would charge 7S batteries I would have tried it. 730mx is a very torqy motor on 6S I think it probably provides the best balance between power,performance and battery life. They run a 16T on the 730mx so the motor doesn't need to spin as fast. That is how they get away with running a low kv. The motor is also physically larger in diameter then 1100kv motors. Think of it like using a longer wrench to break a bolt loose. You don't have to exert as much power to do the same amount of work. I would have even kept my 730mx had they had a larger pinion for it. A 17T I think would do excellent with this motor on a 550. But no one makes one yet. So getting higher head speeds isn't possible.
I moved to 12S on my 550 because I want higher performance and still maintain the long battery life.
HE HE HE i have been looking at that motor,i think that i will order it, for the 550, but to start with i will use 6s bat's, i dont know if my charger can charge 7s, i think that 6s is the biggest
i could see on ebay that i can get all from 11 to 19 tooth pinion, so with one should i order with the motor ???
Greetings Rico
The 730mx isn't bad it can pull some pretty decent current spikes but overall after having the KDE 1100 its very efficient in comparison. On mine I averaged 40 amps and peaks of 150 amps.As long as the ESC can handle the power being pulled by the motor, you should be fine.
