General 550 DFC head setup
thanks tony i did watch those videos...i was looking for the mechanical type...like which links to adjust...i think i got it...i know i can't seem to get 6 degrees of pitch set in the 7200 i got a blue light at 7 degrees.....when setting up the 7200 all sticks should be at center from start to finish right....and thank you for all your help and videos...keep it up...i know i would be lost if it wasn't for you and all the members that help
On my helicopters, I was never able to get a blue light on the bx. I just set it at 6º and called it good.
Hey Dewayne. Make sure you have a level platform to set your heli on. It's not easy but you can get 6 degree/Blue light to match. That heli must sit PLS in order for this to work. Good luck.
