500 500 FB throttle DX6i
trainrider06
ok i know I am missing something here, my 500 that I put together is a pig lifting off! I have to give it almost full throttle to get it to lift off the ground! hmm maybe my swash needs adjusted up or down??
My throttle curve in radio is 0/38.0/50.0/75.0/100. It was linear before and doing the same thing.
My pitch curve was linear also and I adjusted it to 35.5/45.0/53.0/75/100 still does the same....I am missing something I know because I had this same problem before, but I am senile and cannot remember what the hell I did!
What is your overall pitch positive and negative?
Duhh! I have not even checked it....LOL I got it together and leveled the swash/servos and then it sat for weeks because it was raining all the damn time.....then this first day I was off and the weather was clear I grabbed it and threw a pack on it and took it up! I bet my swash is too low/high....duhh! I could tell when I powered it up and was lifting off that the pitch in the blades was leveling off above half stick, and it still didn't dawn on me....
What size motor pinion are you running?
It's a 13 tooth I think D.O.G.
Hi Rodney when I used to fly on none fixed throttle my throttle curve was 0/70/80/90/100 with soft start pitch was -2 at zero mid was 5 to 6 degs top was +12 and I just balanced the points 2 and 4 for a smooth curve
