Hi all,
Have a look at thread #7 about 1 week ago. There I describe how to access the advanced setup features for my Phoenix. If there aren't similar tuning options in Real Flight then all it means is that you can't do anything (or maybe only reduced capabilities?) to try and get your simulator model to function more like the real thing. Up to now, I've only altered the weight and entered the pitch settings as per my Blade Setup (those in the pdf). There are many different parameters available to change. For example, the pop-up on weight tells one to also change the yaw settings, I haven't done this yet. It's next on my list, but I'm not doing 3D etc. yet, so I don't feel any pressure to change anything there right now.
Most significant in my test is to address the question of what settings to use for a beginner. I know all about being a beginner as I'm still classing myself in that category. My main problem has been that I didn't understand the capability of the radio to limit the actions of the heli, I just tried with an expert's view of what the settings should be. Now I do understand and I'm just exploring the relationship between simulator and real. My Guru could fly my Blade no problem but I couldn't.
The principles apply for any combination of heli, radio and simulator. Just accept that you can't run and setup accordingly to crawl, walk, run and then fly (hopefully inverted at the end). As a beginner I have no use for 24 degrees of pitch range, I only need about 2 degrees of positive pitch at most. As my pdf shows that's from plus 4.93 to 6.39, until I began the exercise to discover exactly what it all means, my stick moves gave way too much response from the heli resulting in crash after crash! At least my re-build skills are top notch (always look for the positive
The positive 4.93 degrees allows me to set the heli down gently and not slam it into the ground with negative pitch. The 6.39 limits the altitude I can reach in the hover. The simulator trials give me the opportunity to greatly reduce my crash ratio. I can now measure my performance in batteries between crashes instead of crashes per battery
. My very limited D/R and large Expo Settings limit my potential to turn it over. Yes I need greater stick movement to keep the heli on the spot, but all this can change as my performance improves. Last time out, I was able to make many changes in the radio settings as I improved. The key to being able to succeed is to know what you're doing and not have to turn to someone every time something needs to be changed.
Best regards,
Heliman450
